Schedule Qapp
Example: Create a scheduled task to run the Qapp Overall Health Check [SNMP] from scratch.
  2. In the Domain Management page, click Schedule Task on the Start Page or select Schedule Task from the navigation menu by clicking the  icon on the left .
  3. On the Schedule Qapp tab, click Add Task.
  4. Follow the wizard to configure the Qapp task.
    1. On the Basic Info tab, enter the task name Basic Health Check [SNMP].
      Graphical user interface, text, application, chat or text message, email
    2. On the Target Devices tab, select Add Site > My Network, and click OK.
      Information Tip: If you select an existing path, the devices along this path will be treated as target devices when the path is successfully calculated.
    3. On the Select Qapp tab, click Select and choose the Overall Health Check [SNMP] Qapp, then click OK.
    4. On the Time Settings tab, set the data source, execution time and frequency. In this case, set the frequency to Daily.
      Information Note: For the data source, if you select the Current Baseline, you should make sure there is historical data.
      Information Note: The time zone settings refer to the time zone of NetworkBrain Web Server.
    5. On the Output tab, click Submit. If the selected Qapp support CSV report generation, you can export the report file to a Shared Network Folder as shown in the following image.
    6. Information Note: For Qapps that can generate alerts, configuring Email Server Settings are required before alerting emails can be sent.
