Configure Incoming Email Server Settings
To configure Incoming Email Server Settings, complete the following steps:
  2. On the System Management page, select the Email Settings tab.
  3. In the Email Settings > Incoming Email Server Settings tab, select the Enable Receiving Email Server Settings check box.
  1. Configure the following fields.
    There are two ways of authentication, Basic Authentication and OAuth 2.0 for Microsoft Office365, and the incoming email server settings are different for each scenario . Two sets incoming email server settings are respectivley described in the two tables below:
    a. Basic Authentication
    FieldDescriptionDefault Value
    Authentication
    Specify the authentication method
    IMTP ServerSpecify the IP address of an IMTP server.-
    IMTP PortSpecify the port number that the IMTP server listens to. 25
    EncryptionSpecify the type of encrypted connection, such as SSL or TLS. -
    Receiver Email AddressSpecify the email address for receiving system emails.-
    Password (Optional)Select to specify a password of the receiver's email address.-
    Collect Unread Email within ( ) Hours every ( ) minutes Specify the time interval for collecting unread emails.
Information Tip: Before saving the changes, you can click Test to verify whether the settings are valid.
b. Authentication via OAuth 2.0 for Microsoft Office365
Field
Description
Default Value
Authentication
OAuth 2.0 for Microsoft Office365OAuth 2.0 for Microsoft Office 365 is selected
Authority Host
Select one Autority Host from the following:
  • AzurePublicCloud - The host of the Azure Active Directory authority for tenants in the Azure Public Cloud
  • AzureChina - The host of the Azure Active Directory authority for tenants in the Azure China Cloud
  • AzureGermany - The host of the Azure Active Directory authority for tenants in the Azure German Cloud
  • AzureGovernment - The host of the Azure Active Directory authority for tenants in the Azure US Government Cloud
AzurePulicCloud
Application (client) ID
Input the application (client) ID.-
Directory (tenant) ID Input the directory (tenant) ID.-
Type
  • Certificate-Based Authentication
    • Upload the certificate.
    • (Optional) Enable password for certificate and enter the password.
  • Password-Based Authentication
    • Provide the client secret value
Receiver Email AddressEnter the member email address listed in the new mail-enabled security group.
Collect Unread Email within * hours every * minutes
Define the frequency of collecting unread emails. 2 hours every 1 minutes
  1. Click Save.
