Check Baseline Data During Intent Execution
If the intent baseline service is applied to an intent (including common intent and intent cloned from NIT), the intent baseline data update shall be checked during intent execution so that the latest baseline data of the intent is obtained.
The following table shows how intent baseline data is checked during different types of NI execution.
Intent Execution Mode | Intent Baseline Data Checking |
Interactive Execution | When one or more intents are executed as a Runbook node, the intent baseline data is directly updated. |
TAF Triggered Execution | Intent baseline data is directly checked and updated during intent execution. |
PAF Triggered Execution | Intent baseline data is directly checked and updated during intent execution. |
