Appendix (ADT Dataset)
Three types of data can be selected from Benchmark:
a. Latest data from current baseline: If current baseline is selected, the system only uses the latest current baseline data to build the ADT dataset.
b. Basic System Benchmark: Data from the system built-in benchmark. Latest Data in this category is the latest benchmark created by the system.
c. Data obtained from the benchmark task at specified execution time: This category covers the benchmarks obtained from benchmark tasks created by a user. Use the data obtained from the benchmark at a specific execution time to build ADT dataset. When this type of data is selected, the corresponding CLI command data will be tagged “ADT referenced” and will not be auto-cleaned.
