AAM License Extension for Running Path NI.
To use the full functions of the application path, you need to purchase an AAM module License. You can execute the path intent unlimitedly even if you do not have PA License.
- When path intents are verified and executed in AAM, the PA license nodes will not be counted to occupy the PA license quota.
- PA license quota will not be counted when path intents are executed from any entrances in the system. The following table lists the details.
Run Path Intent Entrances | Count PA license |
Path Intent Pane and Pop-out Path Intent Dialog | × |
Runbook Intent Node | × |
Preventive Automation | × |
TAF triggers NI or NIC | × |
