Access the Documented Path via A/B Dialog
When inputting or selecting an A/B path, the pre-documented path with the same source/destination will be displayed on the intelligence dialog, where you can view the pre-documented path results and draw its path map.
  1. Click the path icon on the search bar.
  2. Enter the source and the destination IP addresses (device hostnames or DNS names).
  1. Select the required path.
