Topology Link Manager
After building topology in benchmark tasks, you can browse all device connections in each topology type in the Topology Link Manager. You can view details information on each topology type and manually add, disable, or lock a topology link to correct the wrong connection calculated by the system and rebuild a topology type.
Main use flow with Topology Link Manager.
