Device Driver defines the method of retrieving and parsing device data during live access.
Add a Device Driver
- Log in to the Tenant Management page.
- Click
and select Multi-vendor Support from the drop-down list. - On the Device Driver tab, use either way to add new entries to the table list.
Add entries manually
- Click Add. The Device Driver Properties window prompts.
- Enter the device driver name and select a device type from the Device type list.
Note: The Author field is automatically filled with your license ID.
- Configure a series of driver properties, such as Live Access and Config File. See Device driver properties for more details.
- Click OK.
The created device driver is added to the device driver list.
Import a driver file
- Prepare a .drv file in your local folder.
- Click Import at the upper-left corner of the device driver list.
- Select the .drv file and click Open in the pop-up dialog box. The file is imported into the device driver list.
