Data Source
The following table lists the available data sources that can be used for data analysis, such as running a Qapp, and comparing network data.
Data Analysis TypeData SourceDescription
History DataSelect a Time Point
Use the saved device data which is nearest to the specified historical point.
Default search scope: ± 2 hours.
Select a Time Period
Use the latest device data saved during the specified historical period.
For example, there are two benchmark tasks over a specified time, and task1 was executed earlier than the task2. The task1 successfully retrieved the device configuration and ARP but did not get the MAC table, while task2 successfully retrieved ARP/MAC table but did not get the configuration, then the system will use the configuration retrieved in task1 and ARP/MAC table retrieved in task2 as the data source.
Current BaselineUse the latest device data  saved in the database directly.
Live DataPull Live Data OnceLog in to the device instantly to retrieve live data for once.
Pull Live Data RegularlyLog in to the device to retrieve live data regularly based on the customized frequency.
Default Live
Log in to the device instantly to retrieve real-time data.
This option is only available in the following locations:
  • Device Details pane - Configuration File and Data Tables
  • Dashboard widgets, such as Configlet by Config Parser
When you click Retrieve, it will be selected as the data source.
Information Tip: The retrieved data can be saved as current Baseline for history data analysis.
