Live Device Data
The following types of live device data can be retrieved for task execution in a domain:
Note: The available data types may differ depending on the analysis task types and device types. |
- Configuration File
- General Data Tables, including:
Route/ARP/MAC/NDP/STP. - NCT Table, including:
Azure Neighbor Relationship Table, IPsec VPN table, BGP All VPNv4 Advertised Route Table, Cisco Coverage Summary, GRE Tunnels, NAT Table, IPv6 Route Table, BGP advertised-route table, and so on. - CLI Command Outputs
The outputs of the executed CLI commands. For example, the CLI outputs of the show ip bgp summary command or the show ip eigrp neighbors command.
