Viewing Path Results and Details
After calculating a path, you can view the status and result of the path:
View Path Result in Path Result Pane
View Path Result Details in Path Overview Pane
Viewing Path Result in Path Result Pane
The Path Result pane shows the status and the traffic information about a path hop by hop.
Path Status
There are three types of path result status:
Succeeded: all full paths are calculated successfully.
Failed: all full paths are calculated unsuccessfully.
Traffic Information
The traffic information in the Path Result pane includes:
The traffic flow diagram of a path from the source to the destination.
Path types (including L2 Path, L3 Path, and Overlay Path). A Path may contain several types of paths at a hop. To view the result of a path type, click it to display the corresponding path on the map.
Incoming and outgoing traffic interfaces at each hop.
Viewing Path Result Details in Path Overview Pane
The Path Overview pane shows the details of path results based on the following categories:
Full Path: A full path means a complete path from the source to the destination.
Segmented Path: A segmented path means the path between the outgoing interface of a device and the incoming interface of the next-hop (L2 or L3) device.
