Viewing Plugin Execution Status and Logs
After executing a plugin, you can view the execution status and logs.
Plugin Execution Logs
As an additional operation of a scheduled task, the status of a plugin impacts that of the scheduled task as a whole.
Impact to Scheduled Plugin Status:
Plugin  Status
(All Plugins) Succeeded
Succeeded
(All Plugins) Failed
Failed
(Some Plugins) Succeeded
Succeeded with warning
Impact to Benchmark or Discovery Status:
Plugin Status
Benchmark/Discovery Status
(All/Some Plugins) Failed
Succeeded with warning (if the left modules of the benchmark/discovery succeeded.)
Depend on the status of other modules
Viewing Plugin Execution Logs
Proceed with the steps below to view the execution logs of a plugin in a scheduled task:
Note: The printed execution logs of a plugin depend on the log definition in your plugin script.
Example: View the plugin logs in a benchmark task.
1.On the Domain Management page, click Operations > Schedule Task.
2.On the Schedule Discovery/Benchmark tab, right-click a benchmark task and select View Log.
3.In the View Log pane, click the icon in the Log column.
4.View the plugin logs in the Plugin Log pane.
