The system organizes the NSX-V network resources in the Network pane based on NSX components. Follow the steps below to view the discovered NSX components.
2.Select NSX-V from the Category list, and then select NSX-V Components from the View list.
3.Expand a component to view the NSX-V node, such as Edge and its appliances.
4.View Context Maps and Details of an NSX Node.
