Supporting variables contains a group of key metrics referenced or defined in a data view template definition, including:
Built-in variable (GDR property)
CLI/SNMP/API/Configuration Parser variable
Compound variable
Input variable
Supporting variables can be used as or applied to:
Device/interface positions.
Device/interface notes.
Device/interface highlights.
Referenced as a variable to define the conditions for drill-down actions.
Conditions to control the display of variables, device/interface notes, device/interface highlights, and device-level drill-down actions.
Note: Supporting variables belong to the data view template level, and can be used in all branches of a data view template.
Variable Settings
