When discovering network devices, the system uses SNMP strings to retrieve sysObjectID and then decides which device type and which driver can be used to obtain the device data. When SNMP access is not available for some devices, you can manually add definitions to associate drivers with device types, so that these devices can be discovered via CLI commands.
Adding a Network Definition Entry
2.In the Domain Management page, select Operations > Discover Settings > Network Definition from the quick access toolbar.
3.On the Network Definition tab, use either way to add new entries to the table:
Adding entries manually
Importing a .csv file
Managing Multi-Vendor
