On a map, you can run Qapps to highlight devices and interfaces to check network problems or make your network configuration displayed intuitively.
The following table lists the network technology that can be highlighted by running related Qapps on a map:
Network Technology
Qapp Name
Description
OSPF
Check Access List on OSPF Link
Check and highlight OSPF interface configured with ACL.
Check OSPF Corrupt Packet
Check and highlight devices without BAD LSA log.
Check OSPF Authentication
Check and highlight neighboring interfaces without authentication configured.
Check OSPF Link MTU
Check and highlight OSPF MTU on neighboring interfaces.
Check OSPF Link Priority
Check and highlight OSPF interface priority on neighboring interfaces.
Check OSPF Network Type
Check and highlight interface network type on OSPF neighboring interfaces.
Verify HELLO Packets Sent Out of Interface
Verify and highlight HELLO packets sent or received normally.
Verify HELLO Parameters Match
Verify and highlight OSPF neighboring devices with mismatched parameters.
ACL
Highlight Specified ACL
Check ACL name and draw it on the map.
BGP
Highlight BGP
Highlight BGP configuration, AS, neighbors, and summary.
EIGRP
Highlight EIGRP Configuration
Highlight EIGRP configuration and AS number.
ISIS
Check ISIS SPF-Log
Check and highlight devices with ISIS SPF log.
MPLS
Highlight MPLS
Highlight MPLS configuration, interface, and VRF.
Per-VLAN Spanning Tree (PVST)
Highlight PVST
Highlight PVST topology information.
Highlight PVST Configuration
Highlight PVST configuration.
Highlight Switchport Mode
Highlight switch port mode.
Highlight Spanning-Tree Features
Highlight spanning-tree features.
SNMP
Highlight SNMP Community
Check and highlight SNMP community with ACL configured.
Highlight SNMP Group Version
Highlight SNMP group version and security model.
Highlight SNMP Traps
Highlight SNMP traps and display related information.
Multicast
Highlight Shared Tree
Highlight roles and configuration in the shared tree.
Highlight Source Tree
Highlight roles and configuration in the source tree.
VLAN
Highlight Specified VLAN
Highlight the interfaces in the specified VLAN.
Highlight VLAN
Highlight switch trunk port and VLAN access port.
Check VLAN Allowed on Trunk Port
Highlight the VLANs allowed on trunk port.
QoS
Highlight QoS Configuration along Path.
Highlight QoS configuration.
Highlight QoS Interface Queuing Strategy
Highlight QoS interface queuing strategy.
Routing protocol
Highlight Routing Protocol
Highlight devices and interfaces about routing protocol configuration.
Static routing
Highlight Static
Highlight devices and interfaces with static routing configured.
VRF
Highlight Specified VRF
Highlight the interfaces in a specific VRF.
Interface speed and duplex
Check Neighboring Interface Speed and Duplex
Check and highlight neighboring interfaces with speed or duplex mismatched.
Interface MTU
Highlight Interface MTU
Highlight interface MTU.
Neighboring port mode
Check Neighboring Port Mode
Check and highlight neighboring ports with the mismatched port mode.
Interface rule
Check Interface Rule
Check and highlight the interfaces whose status is down and interface description is not null.
Redistribution
Highlight Redistribution
Highlight redistribution configuration.
Running a Qapp
Qapp Center
