Qapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Qapp files.
▪Built-in Qapps — contains the pre-installed Qapps. This category is accessible to all users but can only be modified by system administrators.
▪Shared Qapps in Tenant — contains Qapp files that are accessible to all users in this tenant.
▪My Qapps — contains Qapp files that are only accessible to yourself. You can find your private Qapps in all accessible domains under one tenant.
1.Click the start menu
and select Qapp Center.
2.Point to a Qapp file and click the
icon to preview it.
