Drill-down actions are a group of tasks elaborately designed to analyze and troubleshoot a certain network issue, building a bridge to connect dynamic maps with network automation for diagnosis and troubleshooting.
The system provides two levels of drill-down actions in DVT definition:
▪Template level — perform actions targeting all devices on a map. Drill-down actions at the template level are displayed unconditionally.
▪Device level — perform actions targeting specific devices/interfaces only, and its display is controlled via conditions.
The following table shows whether action input and device scope can be customized at each level of drill-down actions.
Drill-Down Action Level |
Support Customized Action Input? |
Support Customized Device Scope? |
Template Level |
Device Level |
Tip: Action input for most drill-down actions can be customized. See Syntax for Defining Action Input for more details.
Tip: To customize device scope for drill-down actions at the device level, see Syntax for Defining Target Devices for more details.
The following table introduces the drill-down actions that can be defined at the template level and device level.
Drill-Down Action |
Template Level |
Available at Device Level |
Data View Template |
Qapp |
Gapp |
Overall Health Monitor |
Execute CLI commands |
View Device Data |
Ping |
Traceroute |
Calculate Path |
Compare |
SPOG URL |
URL |
Runbook Template |
Verify Application |
