Before discovering a network, you can create a Do-Not-Scan list to specify the IP addresses, subnets, or device types that you do not want to discover in your network. Consequently, the related devices is ignored during the discovery process.
By default, the following device types are selected in the Do-Not-Scan list.
▪IP Phone
▪LWAP
▪Cisco Meraki AP
▪Cisco Meraki Cloud
▪Cisco Meraki Firewall
▪Cisco Meraki Switch
2.Select Operations > Discover Settings > Do-Not-Scan from the quick access toolbar.
3.In the Do Not Scan tab, select either way or both to add do-not-scan devices.
In the device type list, select the check boxes of the device types that you don't want the system to discover. |
