To have quick access to specified dashboard templates when creating a dashboard, you can customize your favorite dashboard templates in the drop-down menu of the map toolbar.
1.On a map page, click Dashboard > Customize from the map toolbar.
2.Click + Dashboard Template, and select dashboard templates by clicking Apply, then click Close.
2.Point to the Dashboard Template Menu node and click the
icon to select New Folder from the drop-down menu.
For how to add templates to the folder, see Adding Templates to Favorites for more details.
