1.Click the start menu
and select Dashboard Widget & Template.
2.Select the Dashboard Templates tab, and point to a category in the left pane and click the
icon to select New Template.
3.Fill in the generic information about the template, including name (case-insensitive) and description.
4.Add widgets into the template.
1)Click + Widget or the
icon. All available widgets are categorized by functionality.
2)Click Select to pick out your interested widgets.
3)Click Submit.
Tip: If you add monitor widgets into the template, click Qapp Settings to set the frequency.
5.Click Save.
▪Customizing Favorite Dashboard Templates
