Predefining a Context Action
Each context action groups a runbook template and a data view (or data view template) that corresponds to a specific context. When you Predefine a Network Context, the context action is required for each context.
To predefine a context action, do the following:
1.Click the Start menu and select Context Action Manager.
2.In the Context Actions dialog, click All Actions node, then click New Action in the drop-down menu.
3.In the Action Details dialog, enter the action name and description, then select the target runbook template. Click OK.
