To quickly duplicate data units in a data view, you can save it as a new one. To do so:
1.Right-click the blank area on the target map and select Data View > Save As from the drop-down menu.
2.Enter the data view name.
3.Specify the data view category, Global or Local. By default, the data views of all devices on the map are saved.
4.Click Save.
