This section introduces the hardware requirements, network connectivity requirements, and more prerequisites for deploying the NetworkBrain system by using a combined OVA (Open Virtual Appliance) solution.
▪Network Connectivity Requirements
Note: A Virtual Appliance is a pre-configured virtual machine image containing a software stack developed to run on the virtual machine platform.
The combined OVA deployment requires one Windows server for applications and one virtual machine for the database.
Environment |
NetworkBrain Component |
Machine Count |
CPU |
Memory 1) |
Hard Disk |
Operating System |
≤1000 nodes |
Application Server |
1 |
4 Core/ |
16GB |
200GB 2) |
▪Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit ▪Windows Server 2016/2019 (Standard/Datacenter Edition), 64-bit |
Database Server Appliance |
1 |
4 Core/ |
16GB |
300GB 3) |
▪VMware ESXi 6.0/6.5 |
1001~2000 nodes |
1 |
4 Core/ |
32GB |
200GB 2) |
1 |
4 Core/ |
32GB |
300GB 3) |
Notes:
1) Allocating at least half of the RAM amount for swap space on your Linux server is required to provide the necessary additional memory when the RAM space has been exhausted.
2) For good performance of data processing and caching, it is recommended to install the Application Server on a machine equipped with Solid State Drive (SSD) when managing up to 5000 nodes.
3) Increase the values through the virtual machine settings if they are insufficient before starting the virtual machine.
Source |
Destination |
Protocol and Port Number *) |
Thin Client |
HTTP/HTTPS (80/443) |
Knowledge Cloud Domain (https://knowledgecloud.netbraintech.com/) |
HTTPS (443) |
Database Server |
TCP 5672/9200/27017/27654 |
Ansible Agent (add-on) |
TCP 50051 |
Live Network |
ICMP/SNMP/Telnet/SSH/REST API |
Note: *) The port numbers listed in this column are defaults only. The actual port numbers used during installation might be different.
