Featured Management Privileges
When creating a user account, you can authorize the featured management modules to this user by selecting System Management, or User Management, or both.
The detailed difference between the two options is described in the following table:
Management Category
Featured Management Module
System Management
User Management
System Management Page
System Home Page, including Usage Report
License
Tenants
User Accounts
Front Server Controllers
Email Settings
Advanced Settings - Global Session Timeout
Advanced Settings - Others
Resource Update
Task Manager
API Adapters
Script Manager
Deployment Status 1)
Service Monitor
Tenant Management Page
User Authorization
Domain List
Multi-vendor Support
Misc Configuration
GDR Data Configuration
API Manager
Interface Type
Platform Management
Topology Link Style
Advanced Settings - Upload Visio Template
Note: 1) Only if you install multiple DC, the Deployment Status is displayed in the list.
