The system adopts Elasticsearch to enhance search behaviors, data accuracy, performance, and scalability. NetworkBrain Index Server is a full-text search and analytics engine in a distributed multi-user environment with high availability and horizontal scalability.
Select either of the following ways to install Index Servers, depending on your system deployment and whether you need data replication:
▪Installing Index Server on Linux
▪Installing Index Server Cluster on Linux (optional for high availability)
▪Collaborating with MongoDB Server
▪Synchronizing Data Manually with Script
