The fundamental element of a Qapp is called a node. Each node contains specific attributes and connects logically.
Example: Nodes in a Qapp Editor
Nodes in the Qapp Editor
The Qapp Editor has two types of tabs:
Execution Flow tab — define the execution sequence of the nodes within a Qapp, as well as the relations or conditions among the nodes.
oStart — the starting point of a Qapp. You can define the way of the Qapp to obtain devices at runtime within this node.
oQapp Description
oGlobal Table
oFilter Criteria
oInput Variables
oCanvas
oIf-condition
oStop — the endpoint to terminate a Qapp. You can define a message and the message will prompt when the Qapp executes this node.
Canvas tab — contain an internal workflow composed of multiple subnodes as follows.
oDevice Queue
oDevice
oCommand
oTable
oTable Operator
oOutput
Context Menu of Qapp Editor
The context menu in the Qapp Editor is as follows:
Icon
Description
Save the Qapp.
Save as another Qapp.
Run the Qapp.
More operations, such as customizing functions and locking the Qapp.
Operating on nodes
Creating a Qapp
