Customizing Qapp Functions
The system provides hundreds of built-in functions (as known as APIs, short for application programming interfaces) for more extensive and flexible usage. In addition, you can customize your own functions in the Qapp Editor.
1.In the Qapp Editor, click More > Function from the Qapp context menu.
2.Use Python syntax to script the functions in the pop-up dialog.
Note: The functions you customized in the Qapp Editor can only be used in the current Qapp file.
Script Output
Qapp APIs
Python scripting
