The advanced settings for each domain include:
Network Security
L3 Topology
L2 Topology
Email Alert for Qapp
Credentials
Live Access
Others
Security
Check Box
Default Value
Description
Remove the following sensitive data from the device configurations and UI
Disabled
The sensitive data include:
1.Line and console passwords
2.Local user passwords
3.Enable passwords
4.Enable Secret
5.SNMP community string
6.TACACS and Radius keys
7.VPN Keys and/or Certs
8.SSH Private keys (these may show up on CSS devices)
Build L3 Topology Option
Check Box
Default Value
Description
Build unknown end system L3 topology
Disabled
Control whether to calculate L3 topology for unknown end systems when building L3 topology in a benchmark task.
Note: Enabling this function may increase the time of building L3 topology in a benchmark task if the system has lots of unknown end systems.
Use the main class mask to calculate L3 topology for an IP without mask
Disabled
Control whether to calculate L3 topology for IP addresses that do not have masks.
When this option is enabled, the system calculates L3 topology for theses IP addresses by borrowing the masks of their main class network addresses.
Automatically create zones and assign VRF interface based on VRF names
Disabled
Control whether to automatically create zones based on VRF names.
If this function is enabled, the system does the following when detecting two interfaces configured with the same IP address but different VRFs.
1.Create a zone per VRF after the IPv4 L3 topology is built.
2.Move the two interfaces to the corresponding zone according to its configured VRF.
Build L2 Topology Option
Field/Check Box
Default Value
Description
Minimum subnet mask
16
The minimum network number that the system can calculate when building L2 topology.
Filter DHCP Entries
Disabled
If enabled, the system filters out the outdated DHCP entries and only keeps the latest IP addresses when building build L2 topology.
Only save One-IP table entries that have values in Switch Port or DNS Name parameter
Enabled
If enabled, the system only saves entries with switch ports and DNS names in the One-IP table. It helps decrease the storage size and increase the query efficiency of the One-IP table.
Configure Email Alert for Qapp
Option
Sample Email
Merge all alerts in one email (default)
Sample Email Title: xxx errors xxx warning detected in Domain_Name
Separate alert emails for different tasks
Sample Email Title: xxx errors xxx warning detected in Task_Name
Sample Email For Task 1:
Sample Email For Task 2:
Separate alert emails for different objects (devices or paths)
Sample Email Title For Device: xxx errors xxx warning detected on Device_Name
Sample Email For Device 1:
Sample Email For Device 2:
Sample Email Title For Path: xxx errors xxx warning detected on Path_Name
Sample Email For Path:
Duplicate an alert in emails when alert count increases by X
The delta threshold (X) controls when the system will email an alert again if it is repetitively recurring and increasingly reaches the value.
By default, the value is 60.
Access Credential for Telnet/SSH CLI, Smart CLI and Change Management
Option
Description
Use Private Credentials and Shared Privilege Credentials
Use credentials defined in the Private CLI Settings to log into devices and then use privilege credentials defined in the Shared Device Settings to enter the privileged mode. It is the default access credential mode.
Use Private Credentials and Private Privilege Credentials
Use credentials in the Private CLI Settings to log into devices and then use privilege credentials defined in the Private Device Settings to enter the privileged mode.
Use Shared Credentials and Shared Privilege Credentials
Use credentials defined in the Shared Device Settings to log into devices and then use privilege credentials defined in the Shared Device Settings to enter the privileged mode.
Live Access
Field/Check Box
Default Value
Description
Timeout
SNMP
2 seconds
The timeout value when an SNMP request does not get a reply.
CLI
30 seconds
The timeout value when a CLI request does not get a reply.
SNMP Hostname
Trim all strings after dot in SNMP hostname
N/A
Trim all strings after the dot in an SNMP hostname and use the remaining strings as the hostname in the system. For example, device.core1. The system trims .core1 and use device as a hostname in the system.
Trim following domain names from SNMP hostname
N/A
Trim the specified domain names from an SNMP hostname.
Management Interface Selection Order
management;loopback;vlan;ve;ethernet
The order of interface types used to set the management interface of a device.
Polling Order
Trying to login device directly, then login via Jumpbox
N/A
Attempt to direct log in to devices first and attempt login via Jumbox if the direct login fails.
Trying to login device via Jumpbox, then login directly
N/A
Attempt to log in to devices via Jumbox first and then attempt direct login if the login via Jumpbox fails.
If ping fails, don't try Telnet/SSH in Tune Live Access and Seed Discovery
N/A
When the ping to a device fails, the system will not attempt Telnet/SSH access in the Tune Live Access and Seed Discovery features.
If ping fails, don't try SNMP/Telnet/SSH in Scan IP Range
N/A
When the ping to a device fails, the system will not attempt SNMP/Telnet/SSH access in the Scan IP Range feature.
Third Party Telnet/SSH Tool
Enable Telnet/SSH CLI via third party tool
N/A
Whether to call third-party Telnet/SSH tools in NetworkBrain systems. See Logging into a device via CLI for details.
Others
Field
Default Value
Description
Max Route Table Entries
10000
The maximum route entries that the system can retrieve from the routing table of a device.
Limit how parser original results are saved
Minimum Time Interval
6
The minimum time interval that the system automatically saves the original result of a parser.
Maximum Size
2
The maximum size of the original result of a parser that the system can save.
