1.Click the start menu and select Dashboard Widget & Template.
2.On the Widgets tab, point to the category in the left pane and click the icon to select New Widget from the drop-down menu.
3.Fill in the generic information about the widget, including name (case-insensitive) and description.
4.Select the data source for the widget.
Select Qapp as Data Source
Select Data Table as Data Source
5.Click Save.
Widget Type
Type
Description
Generic Table
Display metrics in a table. It has the following options:
Single Device Data Table — displays the metrics of a single device in the table. You can navigate to the data of another device one by one.
Multi-Device Data Table — displays the metrics of multiple devices in the same table.
Event — displays Qapp event details in the table.
Generic Chart
Display metrics in a chart. It has the following options:
Device Metric Chart — displays the trend of single-value metrics of a device over a period of time in the chart.
Interface Metric Chart — displays the trend of interface metrics or multiple-value device metrics during a time period in the chart.
Event — displays the total number of Qapp event statistics in the chart.
Generic Widgets
