You can call parsers in many modules of your NetworkBrain system, such as Qapp, Data View Template and Schedule Parser. This section introduces how to apply a parser in the following modules:
▪Calling a Parser in Instant Qapp
▪Calling a Parser in Qapp Editor
You can call a parser and its variables and drag the variables to a map for data viewing.
1.Search for a specific parser in the map search bar.
2.Drag a variable to the devices on the map.
3.The real-time value of the variable will be displayed once retrieved.
See Searching for CLI Commands and Mapping Matched Results for more details.
You can call a parser and its variables when creating a Qapp: in the Command node of a Qapp, click Select Parser. The variables of the selected parser will be auto-loaded in the variable tree.
