The following is the built-in enums in categories:
Message
Color
Alert
Line
Alignment
Note
Layout
Device Group
Message
Message Level
Description
MessageLevel.Information
Information level.
MessageLevel.Warning
Warning level.
MessageLevel.Error
Error level.
MessageLevel.System
System notification message, generated by the system.
MessageLevel.PythonError
System error message, generated by the system.
Alert
Alert Level
Description
AlertLevel.Warning
Warning level.
AlertLevel.Error
Error level.
Color
Color.RGB(red, green, blue) — used to set the color. It returns the int value of a specified RGB color.
Color.Random — used to generate a random color. It returns -1.
The correspondence of a color and its RGB value is as follows:
Color
RGB Value
Color.Black
RGB(0, 0, 0)
Color.Red
RGB(255, 0, 0)
Color.Orange
RGB(255, 128, 0)
Color.Green
RGB(0, 255, 0)
Color.Yellow
RGB(255, 255, 0)
Color.Blue
RGB(0, 0, 255)
Color.Pink
RGB(255, 0, 255)
Color.Cyan
RGB(0, 255, 255)
Color.White
RGB(255, 255, 255)
Line
Line Style
Description
LineStyle.Solid
LineStyle.Dash
LineStyle.Dot
LineStyle.DashDot
LineStyle.DashDotDot
Alignment
Align
Description
Align.Left
Aligned to the left
Align.Center
Aligned to the center
Align.Right
Aligned to the right
Note
Type
Description
NoteType.Append
When a note with the same title already exists, append new note text to the end of the existing note text and update the timestamp.
NoteType.Overwrite
When a note with the same title already exists, replace the text of the existing note with new note text and update the timestamp.
NoteType.RecordHistory
When a note with the same title already exists:
If the text of the existing note does not exist or there is one piece of text, add new note text and timestamp to the top of the existing note.
If the existing note has two pieces of texts and the new note text context is not the same as the existing text content, add new note text and timestamp to the top of the existing note. If the new text content is same as the existing text content, the note only retains the latest text and oldest text.
Layout
Layout Style
Description
LayoutStyle.Symmetric
Symmetric layout style
LayoutStyle.Circular
Circular layout style
LayoutStyle.Hierarchical
Hierarchical layout style
LayoutStyle.Orthogonal
Orthogonal layout style
LayoutStyle.Tree
Tree layout style
To view map layout styles in detail, refer to Layout Style.
Device Group
Device Group Type
Description
DeviceGroupType.Public
A shared device group in your domain.
DeviceGroupType.My
A private device group in your domain.
See Device Group for more details.
