VMware NSX is the network virtualization platform for the Software-Defined Data Center (SDDC), which delivers networking and security entirely in software, abstracted from the underlying physical infrastructure.
The system can discover the networks based on VMware NSX-v (VMware NSX for vSphere) and then visualize the NSX-v networks on dynamic maps.
Example: A Visualized Topology Map of an NSX-v Distributed Logic Router.
Follow the steps below to visualize your NSX-v network:
2.View NSX-v Network Components
3.View Context Maps and Details of an NSX-v Node
