Use this API to update a role and its privileges.
Resource Information
Method
URL
Required authentication
PUT
/V1/CMDB/Roles
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Request*required
(body)
The body contains the following parameters:
newRoleName (string): a new name of the role. No change will be made if newRoleName, description, and privileges fields are all null.
roleName*(string): the name of the role that you want to update.
description (string): the description of the role.
privileges (string): the privileges that the role owns.
Example:
  "newRoleName""Role Name",
  "roleName""Role Name",
  "description""string",
  "privileges""string"
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
