Use this API to update a domain.
Method |
URL |
Required authentication |
PUT |
/V1/CMDB/Domains |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪domainId*(string): the name of the domain that you want to update. ▪domainName (string): the name of the domain that you want to update. ▪description (string): the description about the domain. ▪maximumNodes (integer): the maximum license nodes that the domain owns. The number must be greater than 0. ▪maximumPorts (integer): the maximum number of SDN ports that the tenant owns. ▪maxinumCPU (integer): the maximum number of SDN CPU processors that the tenant owns. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
