Use this API to update a benchmark task.
Resource Information
Method
URL
Authentication
PUT
/V1/CMDB/Benchmark/Tasks
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Request*required
(body)
The body contains the following parameters:
taskName* (string): the name of the task.
description (string): the description of the task.
startDate* (string): the date when the task starts to run. The standard time format is required. For example, 2017-07-13, or 2017/07/13.
schedule* (object): the schedule to run the task. The following subparameters are included in this object:
ofrequency* (string): the frequency to run the task. It includes ”once”, “hourly”,” daily”, “weekly” and “monthly” options.
ointerval (integer): the interval to run the task. This field is only valid for “hourly”,” daily”, and “weekly” options and the default value is 1, such as every 1 hour, 1 week.
ostartTime* (string): the time to run the task. The time format is full UTC time. For example, 2017/7/11 16:20:20.
Note: Set the time according to your IIS server timezone.
oweekday (integer): the day of the week to run the task. This field is only valid when the frequency is weekly.
0: Sunday
1: Monday
2: Tuesday
3: Wednesday
4: Thursday
5: Friday
6: Saturday
odayOfMonth (integer): which day of a month to run the task. This field is only valid when the frequency is monthly. The default is 1.
oMonths: which month to run the task. This field is optional and only valid when the frequency is monthly. The default value is 12.
deviceScope* (string): the devices included in this task. The device scope includes three types - 'all’, ‘deviceGroup’ and 'site’.
oFor the deviceGroup type, the scope should be the array of full path of deviceGroups. For example, Public/xxx, Private/xxx, or System/xxx.
oFor the site type, the scope should be the array of full path of sites. For example, My Network/Unnamed-site1/Site1.
limitRunMins (string): the time used to retrieve the data. When it reaches the specified time, the task will stop retrieving more data.
cliCommands (string): the customized CLI command to retrieve data. For example, show version.
isBuildIPv4L3Topo (bool): determine whether to build IPv4 L3 topology. The default value is false.
isBuildIPv6L3Topo (bool): determine whether to build IPv6 L3 topology. The default value is false.
isBuildL2Topo (bool): determine whether to build L2 topology. The default value is false.
isBuildIPsecVPNTopology (bool): determine whether to build IPsecVPN topology. The default value is false.
isRecalculateDynamicDeviceGroups (bool): determine whether to recalculate dynamic device groups. The default value is false.
isRecalculateSite (bool): determine whether to rebuild sites. This field is optional and the default value is false.
isRecalculateMPLSVirtualRouteTables (bool): determine whether to recalculate MPLS Virtual Route Table. The default value is false.
isbuildDefaultDeviceDataView (bool): determine whether to build default device data view. The default value is false.
isEnable (bool): determine whether to enable the task. The default value is true.
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
