This section introduces the hardware requirements, network connectivity requirements, and more prerequisites for deploying a two-server system.
Reference Specification
Network Connectivity Requirements
Deployment Prerequisites
The two-server deployment requires one Windows server for applications and one Linux server for the database. Both physical machines and virtual machines are supported.
Environment
NetBrain Component
Machine Count
CPU
Memory
Hard Disk 1)
Operating System 2)
≤1000 nodes
≤10 users
Application Server
1
4 Core/
8 vCPU
16GB
200GB
Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit
Windows Server 2016 (Standard/Datacenter Edition), 64-bit
Database Server
1
4 Core/
8 vCPU
16GB
300GB
Red Hat Enterprise Linux (RHEL) 7.0/7.3/7.5, 64-bit
CentOS 7.0/7.2, 64-bit
1001~2000 nodes
≤10 users
Application Server
1
4 Core/
8 vCPU
32GB
200GB
Database Server
1
4 Core/
8 vCPU
32GB
300GB
Notes:
1) The required hard disk space must be exclusively reserved for NetBrain. For better performance, MongoDB Server is recommended to be installed on a machine equipped with Solid State Drive (SSD), or Hard Disk Drive (HDD) RAID-10.
2) Individual Front Server is supported on both Linux and Windows Server, including 2008 R2 SP1, 64-bit.
Source
Destination
Protocol and Port Number
Thin Client
Application Server
HTTP/HTTPS
Application Server
Database Server
TCP 27017/27654/9200
Application Server
Live Network
ICMP/SNMP/Telnet/SSH/REST API
