Set value for a specified interface attribute
Use this API to set a value for a specified attribute of an interface.
Resource Information
Method
URL
Required authentication
PUT
/V1/CMDB/Interfaces/Attributes
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
Request*required
(body)
The body contains the following parameters:
attributeName*(string): the name of the attribute to set value.
attributeValue*(string): the value to set for the attribute.
hostname*(string): the hostname of the device.
interfaceName*(string): the full name of the interface.
Example:
  "attributeName""loc",
  "attributeValue""Boston",
  "hostname""Bos-Core1",
  "interfaceName""Ethernet0/1"
Response
Parameter
Type
Description
Example
statusCode
integer
The returned status code of executing the API.
  "statusCode"790200,
  "statusDescription""success"
statusDescription
string
The explanation of the status code.
