Use this API to set a value for a specified attribute of a device.
Method |
URL |
Required authentication |
PUT |
/V1/CMDB/Devices/Attributes |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪attributeName*(string): the name of the attribute to set value. ▪attributeValue*(string): the value to set for the attribute. ▪hostname*(string): the hostname of the device. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
