Use this API to keep control over a transaction throughout the process of site modification. Control over the transaction is extended by 30 seconds every time when one of the following operations is sent:
▪Create/delete site
▪Add/replace/delete devices from site
▪Send heartbeat call
If none of the above calls are made after 30 seconds, the transaction would be in the unlocked state. In the unlocked state, if another user opens a new transaction, your transaction would be discarded, and the new user will have control over modifying the site.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Sites/Transactions/Heartbeat |
Yes |
Name |
Token*required |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
