1.Enter one of the following keywords in the search bar:
Data Source |
Sample Keyword |
Dashboard name |
Core Device Details |
Device hostname in the dashboard |
Gw2Lab |
2.Click the
icon or press the Enter key on your keyboard to start searching. The search results will be displayed under the Dashboard group in the lower pane with the matched keyword highlighted.
3.Point to the target dashboard entry and then click the
icon. Select one of following operations based on your needs:
▪Open the dashboard in a new tab page.
▪Delete the dashboard.
▪Using Dashboard to Visualize Multi-Dimensional Data
