The system provides several built-in scheduled Qapp tasks to create global data views.
Note: Only the users with the Qapp Scheduler Management privilege can access the Qapp Scheduler.
To enable the schedules:
1.Click the start menu and select Qapp Scheduler.
2.In the Qapp Scheduler page, enable the target tasks. By default, the built-in Qapp tasks will auto-generate global data views.
Tip: To view or change any setting, right-click a target entry and then select Edit.
Device Group
Gapp
Site
Data View
