After creating a dashboard, you can extract all widgets in it and save them as a dashboard template for future use.
1.On the current dashboard page, click the
icon on the upper-right corner and select Save As Template from the drop-down menu.
2.Select a location to save the template, and enter the template name and description.
3.Click OK.
▪Creating a Dashboard Template
