1.Click the start menu
and select Dashboard Widget & Template.
2.In the Dashboard Template and Widget Manager, select the Dashboard Templates tab.
3.Point to the category in the left pane and click the
icon to select New Template from the drop-down menu.
4.Fill in the generic information of the template.
1)Enter a template name (case-insensitive).
2)Add a short description to describe the template.
5.Add widgets into the template.
1)Click + Widget or the
icon. All available widgets are categorized by functionality.
2)Click Select to pick out your interested widgets.
3)Click Submit. The selected widgets are populated to the Template Contents area.
6.(Optional) If you add monitor widgets into the template, click Qapp Settings to set the frequency.
7.Click Save.
