You can customize a dashboard based on your needs:
Repositioning Widgets
Resizing Widgets
Grouping Widgets
Configuring Qapp Settings
Device Scope
More Settings
Just grab a widget with your mouse and move it around. Other widgets should adopt and re-position intelligently to make a place for the widget you are moving. The positions are automatically saved when dropping a widget.
Resizing Widgets
When pointing to a widget, you will see that a gray arrow appears in its lower-right corner. Use that icon to re-size widgets, and their contents will adapt to the new size automatically.
Grouping Widgets
To enable multiple widgets to share the same target devices, you can group widgets by linking them together.
1.Click the icon at the upper-right corner of a widget, and select Link Widget Together from the drop-down menu.
2.In the editing mode of Group A, click the on the other widgets that you want to link together.
3.Click Yes to save changes and exit the edit mode of Group A.
Configuring Qapp Settings for Dashboard
Each dashboard can contain more than one Qapp, and each Qapp can be associated with multiple widgets in a dashboard.
To configure the settings for all Qapps associated with a dashboard:
1.Click the icon on the upper-right corner of the dashboard, and select Qapp Settings from the drop-down menu.
2.Configure the data source and execution frequency for the Qapps.
3.To edit the threshold of the parameters in the Qapp, click the icon.
Device Scope
Device scope contains all target devices involved in the current dashboard. All widgets in the dashboard share the same device scope.
Map widget can have its own device scope, which may differ with the device scope of the dashboard. You can merge the device cope of Map widget into the device scope of the dashboard.
Generic Widgets
Dashboard Widget and Template
