Use this API to run a benchmark task immediately.
Method |
URL |
Authentication |
POST |
/V1/CMDB/Benchmark/Tasks/{task}/Run |
Yes |
Name |
Token*required |
task*required |
The ID or name of the benchmark task you want to run. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
