Use this API to remove users from a domain.
Method |
URL |
Required authentication |
DELETE |
/V1/CMDB/Domain/Users |
Yes |
Name |
Token*required |
Request*required |
The body contains the following parameters: ▪domainId*(string): the ID of the domain that you remove users from. ▪users*(list): a list of users you want to remove. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
