Use this API to remove a device from a domain using a list of hostnames or IPs.
Method |
URL |
Required authentication |
DELETE |
/V1/CMDB/Devices |
Yes |
Name |
Token*required |
Request*required |
The body must contain one of the following two parameters: ▪IPs (list): a list of management IP addresses of the target devices. ▪hostnames (list): a list of hostnames of the target devices. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
