The Qapp-based report is one of the inventory report types, the data source of which comes from the outputs generated by running a Qapp, such as FRU Report, Stackable Switch Report and VSS Report. See Customized Report for more description.
Exporting a Qapp Report
1.Click the start menu and select Inventory Report.
2.In the left pane, select a Qapp report. The report data is displayed with the data generated in the last time.
3.For the predefined Qapp report, the data source defaults to the live network. To change the data source, click the icon.
4.To retrieve data for the Qapp report with the specified data source, click Run.
5.Click Export.
Tip: The default location of the exported file is C:\Users\<your username>\Downloads. If the outputs of the selected Qapp contain several CSV reports, you can only select one sheet to export.
Customizing a New Qapp Report
Each Qapp Report needs to be bound with a Qapp file with CSV output. By default, there are three built-in Qapps for generating the inventory reports as mentioned above. You can also write your own Qapp to get a customized inventory report. See Creating a Qapp to Export Network Data to Local CSV File for more details.
With the customized Qapp file, you can follow the instructions to customize a new Qapp Report.
2.Click Go to Manage Reports Page at the upper-right corner.
3.Click New Inventory Report on the new page. A wizard will prompt to guide you through the steps to create a report.
4.Enter the report name and description, and then click Next.
Tip: To make the report accessible to more users in the current domain, you can select the Share to all check box and it will be categorized into Customized Reports > Shared Reports.
1)Specify the devices to be included in the inventory report. Then click Next.
Built-in Group — select a site, device group or device type as device scope.
Customized Group — search for the target devices by setting criteria in Dynamic Search.
2)Select Qapp Report as the report type and the corresponding sample will be displayed for reference. Click Next.
3)Select an inventory report Qapp and specify the data source. Click Next.
4)Preview the first five entries of the report. Click Finish.
5.To view the created report, point to the report entry, and then click the icon to select View.
