The Port to Protocol list records the correlations between port numbers and protocols, which can help to specify protocols and ports for calculating A-B paths.
1.Log into Tenant Management page.
2.In the Tenant Management page, select Misc Configuration > Port to Protocol List. The port to protocol list is displayed.
3.Perform the following operations based on your needs.
1)Click Add at the upper-left corner. 2)In the Add Port to Protocol dialog, enter the protocol name, description, port number, and select the transport protocol from the drop-down list. Tip: By default, the Auto Update check box is selected to synchronize the list with NetBrain Server. The system maintains the Port to Protocol list periodically to keep it up-to-date. If the system does not support any protocol you want to use, contact NetBrain Support Team to report the issue. 3)Click OK. The new entry will be added to the list. |
Click Export at the upper-left corner. Tip: The default location of the exported file is C:\Users\<your username>\Downloads. |
